scoobyluke Posted November 18, 2011 Author Share Posted November 18, 2011 Great so any ideas on the gearbox ? Link to comment Share on other sites More sharing options...
kyekye09 Posted November 18, 2011 Share Posted November 18, 2011 there should be a bar code and a series of numbers on the front of the gearbox bud you will get the ref number there Link to comment Share on other sites More sharing options...
jonnyricer Posted November 19, 2011 Share Posted November 19, 2011 Do a gear box oil change first mate best use proper Honda gear oil !! Link to comment Share on other sites More sharing options...
scoobyluke Posted November 19, 2011 Author Share Posted November 19, 2011 Cheers mate - i will give that a go first - the sound is getting louder though so i recon it is b****red. It almost sounds like a broken tooth rather then a bearing... See how things go Link to comment Share on other sites More sharing options...
mantior Posted December 15, 2011 Share Posted December 15, 2011 I used to have an early SR VTEC, and my gearbox also started whining in 1st & 2nd - it's the input shaft bearings as far as I can remember.I swapped mine for one off an EJ coupe - any D Series box (certainly 91-01) will fit. Link to comment Share on other sites More sharing options...
