Engine fault light on, won't give code, won't reset.
Didjeridave
Evenin'
After a load of work to suspension & fuel pump replacement I've got the engine light on. Ecu reset (battery disconnected all night) won't clear it & there's no code flashing when the two-pin connector is bridged. Any ideas?
aye, thought connectors might be a possibility. That 6P connector for the fuel tank was a pain in the rear to get apart easily, shall look at that first.
...and I thought I'd done scrabbling under cars for a short while... pfff
