vti4mark Posted October 3, 2009 Share Posted October 3, 2009 http://cgi.ebay.co.uk/HONDA-CIVIC-1-8-V ... 286.c0.m14looking at getting it in the next few weeks once ive fitted the rest off my stuff.thanks mark Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 3, 2009 Share Posted October 3, 2009 Im not sure what to make of that , every map is differant due to each car having differant mods and engine wear and so on , i would not just buy that fit it and go out in the car with out knowing what it was doing you are alway best to get a mapperable ecu such as hondata s300 and get it mapped to suit the car . it will save you engine damage in the long run. Rich. Link to comment Share on other sites More sharing options...
Guest paul-mb6 Posted October 3, 2009 Share Posted October 3, 2009 it says on the listing that it disables the knock sensor,surely thats a bad thing? Link to comment Share on other sites More sharing options...
tontvti Posted October 3, 2009 Share Posted October 3, 2009 Do our cars even have knock sensors?I know the GSR did, so i think it means it disable the circuitry otherwise you would get an error message using it in a car with out knock sensors Link to comment Share on other sites More sharing options...
tontvti Posted October 3, 2009 Share Posted October 3, 2009 rich, random question but kind of relevant. The ebay manifold you sold for your brother had an extra O2 bung in there for a wideband sensor.Did the car run quite lean after you fitted the exhaust and the decat. I know the long term fuel trim should fatten up the whole tune over time but what was it like straight after it was fitted? Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 3, 2009 Share Posted October 3, 2009 Thats the point i was making if you were to put it on and race around at 9200 rpm witch we all would because it would sound great the engine would not last 5 mins thats if the fueling was right . the only sort of chip or ecu you can fit is like all the new car that just give you another 25 bhp or so . other than that a proper map on a dyno is the only way to do it . i have always done that and have still had problems ,last time ending in an engine rebuild . Rich. Link to comment Share on other sites More sharing options...
tontvti Posted October 3, 2009 Share Posted October 3, 2009 ^ question Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 3, 2009 Share Posted October 3, 2009 rich, random question but kind of relevant. The ebay manifold you sold for your brother had an extra O2 bung in there for a wideband sensor.Did the car run quite lean after you fitted the exhaust and the decat. I know the long term fuel trim should fatten up the whole tune over time but what was it like straight after it was fitted?Yes mate it did have a extra o2 sensor hole in it . I never had it checked mate as they were only bolt on's plus the o2 sensor will change any very small changes like that , he has been running it around for 12 months now with no problems , he does not hang about . Rich Link to comment Share on other sites More sharing options...
tontvti Posted October 3, 2009 Share Posted October 3, 2009 ok, I need to wire up my LC1 wideband (I hate electronics) and was worrying abit that she's running lean with the new exhaust.Apparently the short term fuel trim can adjust fueling up to 30% via the O2 sensor and then the long term fuel trim applies this to the whole tune, so I guess it should be safe if you baby the car in part throttle for a while before hoofing it Link to comment Share on other sites More sharing options...
