engine coolant temperature sensor
Didjeridave
Managed to get at this today & the sensor was measured at 5kOhms with a cold engine. No mention of the correct value in the manual, only the gauge sensor. I guess it'd test as an open circuit if it had failed, so looks like it's hours of wire testing :(
Unless there's any other ideas from anyone?
5 is about right ,value would drop when hot,im pretty sure :idea: try that or put another in :!: try continuity on the available plugs thats worth a try also :idea:
Had a look, the ground wire to chassis is fine & the wire to the ecu has 5V potential. The sensor tested fine again, nearer 4k this time but it was a warmer evening. Ecu has been reset twice & it still returns after a few minutes. Damn annoying! Any ideas before I chuck a new sensor at it?
Cheers.
