andrew1 Posted March 17, 2012 Share Posted March 17, 2012 Hi i have noticed that the clear cover/lens on one of my front lights is fading to a yellowish colour any advice on on how to restore it ?? I have tried polish and also G3 but no luck thanks Quote Link to comment Share on other sites More sharing options...
ryan.. Posted March 17, 2012 Share Posted March 17, 2012 what lights are you using?Sounds like you are burning the inside of the lense with the lights. Quote Link to comment Share on other sites More sharing options...
andrew1 Posted March 18, 2012 Author Share Posted March 18, 2012 sorry i meant that that the outside plastic is turning yellow not the inside lens Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted March 18, 2012 Share Posted March 18, 2012 Polishing is the way forward, but it takes some work to get through that yellow oxidised layer. Keep at it! Even a bit of very fine grit emery paper might be needed to get enough material removal, but too much/uneven removal will spoil the appearance & beam. Careful with powered polishing wheels on plastic! Even toothpaste gives ok results, but then that's basically mint flavoured Autosol....ok, it's a little more different. Quote Link to comment Share on other sites More sharing options...
andrew1 Posted March 19, 2012 Author Share Posted March 19, 2012 Polishing is the way forward, but it takes some work to get through that yellow oxidised layer. Keep at it! Even a bit of very fine grit emery paper might be needed to get enough material removal, but too much/uneven removal will spoil the appearance & beam. Careful with powered polishing wheels on plastic! Even toothpaste gives ok results, but then that's basically mint flavoured Autosol....ok, it's a little more different.THANKS Quote Link to comment Share on other sites More sharing options...
Guest Posted August 27, 2012 Share Posted August 27, 2012 I've seen on here that cheap asda toothpaste works rather well Quote Link to comment Share on other sites More sharing options...
Raz s Posted August 30, 2012 Share Posted August 30, 2012 I used 800,1000,1200,2000 then g3 on my first car (bug eye clio lol) aswell as my mb, that works well but as said above be patient and be carefull i did b****r a light on the clio using the machine polisher but caught it just in time. Quote Link to comment Share on other sites More sharing options...
