remote central locking
aerodeckcrewser
Hi guys. Red key probably works only for learn procedure for learning a new key to immobiliser unit. I haven't find any mention about learning a new keyfob to keyless central locking unit in service manual (but there is a procedure how to use red key for immobiliser learn).
Anyway, as I've just written in simmilar topic, OEM keyfob system seems to use fixed code (since its infrared, it has very limited range and unidirectional transmit beam, so it is not easy to sniff), so it should be easy to replicate second one, if you have at least one working.
  • 4 weeks later...
Don't use the red key in the ignition or you'll completely immobilise the car and Honda will have to sort which means lots of £££ in bills!
