dr.slimm Posted July 7, 2012 Share Posted July 7, 2012 Hi guys. Red key probably works only for learn procedure for learning a new key to immobiliser unit. I haven't find any mention about learning a new keyfob to keyless central locking unit in service manual (but there is a procedure how to use red key for immobiliser learn).Anyway, as I've just written in simmilar topic, OEM keyfob system seems to use fixed code (since its infrared, it has very limited range and unidirectional transmit beam, so it is not easy to sniff), so it should be easy to replicate second one, if you have at least one working. Quote Link to comment Share on other sites More sharing options...
Krzys Posted August 1, 2012 Share Posted August 1, 2012 Don't use the red key in the ignition or you'll completely immobilise the car and Honda will have to sort which means lots of £££ in bills! Quote Link to comment Share on other sites More sharing options...
dr.slimm Posted August 1, 2012 Share Posted August 1, 2012 I would suggest don't use red key until you know what you are doing, there is a procedure how to use it described in service manual... Quote Link to comment Share on other sites More sharing options...
