Throttle position sensor
Rippy
A 12v feed can be taken from behind the radio constant or a feed that gos on and off with the ignition.
As for the throttle position sensor output signel you can tap into one of the 2 wires that comes of the sensor on the inlet manifold . or if you need an in car feed the wires go to the ecu in the passangers foot well you can tap into it there . Rich.
