DIY mot/nct pre checks - engine
james
Test of Fuel system
Any fuel leak will result in a fail. Checked under the bonnet and throughout the run of the fuel line from the fuel tank to the engine.
fuel filler cap must fasten securely
the seal in the cap must not be torn, deteriorated or missing (includes self-sealing flaps)
no other defect which could cause fuel to leak out
the fuel tank must be securely mounted.
Test of Exhaust system and Emissions
The exhaust system will fail the MOT if:
Part of the system missing or excessively deteriorated
Mounting are missing or damaged so that the exhaust system is insecure
There is a major leak
The system emits appreciably more noise than a similar vehicle fitted with a standard system in good condition.
Emissions
These are checked using specialised equipment, the details of the check depending on the year that the vehicle was first used on the road. Excessive smoking (checked visually) is a reason for failure.
Diesel smoke emissions are checked by using a smoke meter.
Fluid Levels
Brake, Clutch, Oil, Powersteering, Coolant, Windscreen Washer Fluid Must Be All between the min and max mark
