james Posted July 8, 2012 Share Posted July 8, 2012 MOT Test of Horn Horn: MOT Checksoperationcontrol can be easily reached by the driverloud enoughnot a sequential multi-tone.InformationPre 1906 vehicles can have a gong, bell or siren audible warning, provided they were designed before 1 January 1905 and constructed before 31 December 1905Reason for RejectionThe horn control missing, insecure or not readily accessible to the driver Note: Inform the driver if the horn is insecureThe horna. inoperativeb. is not loud enough to be heard by another road userc. is a gong, bell or sirend. has more than one toneNote: When operated, a two or more tone horn automatically produces a sound whichalternates at regular intervals between fixed notese. fitted to a vehicle first used on or after 1 August 1973, emits a sound which is • not a continuous or uniform• harsh or grating.MOT Test of LightsLights: MOT Test Checks DescriptionThe headlamps are checked for alignment with a Beam Setter. After first aligning the equipment with the vehicle, the left and right headlamp beams are checked to ensure they are correctly set so as not to dazzle other road users.All required lights are checked for:operationconditionsecuritySide lights and headlampsare the correct type and colourdip and aim.Stop lights, indicators and hazard lights*are the correct type and colourdo not interfere with each other in operationdriver's tell-tale works with respect to indicators, or there is an audible warning system.Rear Fog lamps**must be fitted to the centre or offside of the vehicletell-tale must workmust not be affected by other lamps and not be obscuredmust be red.Number plate lampsAll lamps fitted must be working.Rear reflectorsThere must be two red reflectors fitted reasonably symmetrically, securely attached and not obscured.* Must be fitted to all vehicles first used on or after 1st April 1986, but if fitted, must be Tested.** Must be fitted to all vehicles first used on or after 1st April 1980. Quote Link to comment Share on other sites More sharing options...
