DIY mot/nct pre checks - chassis & suspenion
james
Test of Suspension
Under bonnet checks
upper suspension joints
any other suspension components which can be inspected from beneath the bonnet
Under vehicle checks
Applies to the front and rear suspension
no split pins or nuts missing, no components broken or excessively damaged
road springs are checked for condition
all suspension joints are checked for condition
shock absorbers must not leak and must be secure (the vehicle will be 'bounced' by the Tester to check that they damp the springs adequately).
The suspension is checked for wear by the assistant applying loads in various ways with the wheels jacked up whilst the Tester observes the result from beneath the vehicle. This may include the use of approved wheel play detectors in some Test Stations.
Note: There are numerous different suspension systems, and the specific nature of any examination will depend to a large extent on the design of the suspension system.
