adman Posted July 11, 2012 Share Posted July 11, 2012 Have fault coded my ABS fault to being 11. So Front Right issue. In the workshop manual it explains how to test the resistance to determine where the fault may lie across pins on the connector to the ABS Modulator.Anyone know how to get the connector off? It's pretty awkward to get hands to, but even so, I couldn't see how to get it off. Doesn't come off with a gentle pull upwards, but can't really see if it's got any clips, or should come off in a different direction.Probably just need to bite the bullet and order a new sensor, but would like to run the diagnostics if I can. Quote Link to comment Share on other sites More sharing options...
bitkar Posted November 16 Share Posted November 16 you have to pull the tab on the short side and then pull it out. Just for the case someone goes by. I had the same issue :) Quote Link to comment Share on other sites More sharing options...
