Perconte Posted August 23, 2012 Share Posted August 23, 2012 I own a MB3 wich has a manifold with the cat right on it.I'm planning on getting a D16z6 manifold. When installing this manifold do i need some sort of cat or test pipe to connect it to my mid pipe or is it a straight fit Quote Link to comment Share on other sites More sharing options...
Perconte Posted August 27, 2012 Author Share Posted August 27, 2012 Quote Link to comment Share on other sites More sharing options...
jocky2k Posted September 6, 2012 Share Posted September 6, 2012 it all depends on what your rules are like on emmissons? as i had an mb3 and put a 4-2-1 on it but it kept failing the emmisions due to the egr valve. Quote Link to comment Share on other sites More sharing options...
Perconte Posted September 6, 2012 Author Share Posted September 6, 2012 I know about emmissions, but what I mean is will it be a direct fit on the mid pipe on a MB3?Also changed my mind on the d16z6 and am now searching for the d16y8 manifold. Quote Link to comment Share on other sites More sharing options...
jocky2k Posted September 6, 2012 Share Posted September 6, 2012 no its not a direct fit you need to put a cat on the end of the manni and even then i'm not sure it will fit on the standard mid pipe as when i did it i had a performance mid pipe. Quote Link to comment Share on other sites More sharing options...
