fan staying on
prisspringle
hi guys,
this has only happened 2 times but its a little odd.
when i have switched off the engine and removed the key the fan keeps blowing, i can put the key back in switch the car on and off and it will still stay on till i turn it off on the dial its self( just to note it doesn't work on the 1st setting). sounds like an earth problem but i don't want to go chasing a bad earth if its likely to be something else. any ideas would be great dont want to get out with the fans running and it draining the battery.
many thanks
chris
  • 1 month later...
