wezza9 Posted October 13, 2012 Share Posted October 13, 2012 I have a slight starting problem . when i go to start the car it fires up but does not catch it takes about 3 or 4 goes but runs fine it does not cut out at junctions etc . it does this when cold and warm any ideas ?? is it the dreaded dizzy breaking down ? Quote Link to comment Share on other sites More sharing options...
wezza9 Posted October 13, 2012 Author Share Posted October 13, 2012 ok think it maybe the ingnition barrel so what do i do now with it being a coded key barrel alarm imobliser etc any help or idea ????? i think its that cause when i put the key too the position before start no lights a bit of jigging about it will run Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted October 13, 2012 Share Posted October 13, 2012 I think if you need to change the barrel you do need the keys and the ecu from the donor car. Quote Link to comment Share on other sites More sharing options...
wezza9 Posted October 14, 2012 Author Share Posted October 14, 2012 is there no way of getting stuff recoded ???? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted October 14, 2012 Share Posted October 14, 2012 I know you obviously get new keys coded to the ignition, so it depends if what I said above is right or if the barrel plugs into your ECU then the keys that fit the new barrel would need recoding to your ECU, if that makes sense. Quote Link to comment Share on other sites More sharing options...
