mk1kid Posted November 13, 2009 Share Posted November 13, 2009 hi lads basically battery died on civic so jumped in and srs lights on now i saw the write up on how to get it of basically if im looking at the fusebox theres a yellow plug to my right and to my left the one to my left looks like the 1 in the diagram but the 1 to the right has a spring either side but ive tried putting wire into both and still no joy basically if i have got it right i need to just put a piece of wire in each terminal make sure the other ends are not touching then turn ignition on and after 8 secs the light should go out etc etc plz help Link to comment Share on other sites More sharing options...
vti_aerodeck Posted November 13, 2009 Share Posted November 13, 2009 I was in the same situation as you couple of months ago...Took me a while to figure this out but you have to follow the sequence STEP BY STEP and following the steps STRICLY! eg, if it says 5 seconds, then you need 5 seconds not 6 not 4 etc Hope that helps Good Luck! Link to comment Share on other sites More sharing options...
ShortySco Posted November 13, 2009 Share Posted November 13, 2009 I also had this a few months ago, battery died just like yours, the guide you speak of worked perfect for me... did it several times (just to be sure ) and it worked every time.But yeah, i've heard about other people having problems (think i waited for the light to go off/on rather than counting a preset number of seconds)Also to double check it is the right connector you have, it's plugged into a dummy socket (the socket has no metal contacts inside) Link to comment Share on other sites More sharing options...
mk1kid Posted November 13, 2009 Author Share Posted November 13, 2009 so if im looking at my fuse box which side is it Link to comment Share on other sites More sharing options...
