lacos Posted December 9, 2009 Share Posted December 9, 2009 when checking timing do you have to bridge the check connector if so why?????? Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 9, 2009 Share Posted December 9, 2009 when checking timing do you have to bridge the check connector if so why?????? No mate , who told you that . Rich. Link to comment Share on other sites More sharing options...
lacos Posted December 9, 2009 Author Share Posted December 9, 2009 its in the honda manual thought maybe it stops the ecu detecting a fault when adjusting the dizzy Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 9, 2009 Share Posted December 9, 2009 I through you ment checking the timing as in lining up the timing marks on the cams and bottom pulley . . But i still do not see why you would need to do that . Rich. Link to comment Share on other sites More sharing options...
Guest paul-mb6 Posted December 9, 2009 Share Posted December 9, 2009 you need to short the diagnostic plug to remove any compensations the ecu might be making to the timing Link to comment Share on other sites More sharing options...
