Maxposer Posted May 14, 2013 Share Posted May 14, 2013 hi guys want new lca's for my mb6 i will leave a link cheers guys says it wont fit the car but have been told eg civics fit??? dont know about del sol's http://www.ebay.co.uk/itm/Honda-Civic-E ... 4d0c719f00 Quote Link to comment Share on other sites More sharing options...
marko Posted May 20, 2013 Share Posted May 20, 2013 http://www.ebay.co.uk/itm/EG-DC2-RED-FR ... 4ac48ff82ethat should fit you also get triple the product for twice the price Quote Link to comment Share on other sites More sharing options...
matrix1 Posted May 30, 2013 Share Posted May 30, 2013 Apologies for hijacking thread. Similar problem, I have bought the Skunk 2 Lower control arm for my MB6 ( these are for the EG/Integra, so should fit? ). I have the Meister R coilovers,and therefore the forks can be adjusted to 50mm by taking out the spacers. I have measured the distance between the mounting points on the Skunk 2, and this is different to the factory fitted ones. I s this normal? Will they fit? Has anybody fitted theses? All help much appreciated. Quote Link to comment Share on other sites More sharing options...
matrix1 Posted May 31, 2013 Share Posted May 31, 2013 Ok guys, just wanted to confirm that the Skunk 2 EG Lca's definitely fit. I have the Meister R suspension, so just took out the spacers & the forks went on, no issues. Biggest problem I had was undoing the lca to rta bolt. After struggling with the 13mm 12 point socket was just spinning. Read about the 6 point sockets that are available and bought a set, it just came off no problem. Second problem is realigning the same bolt.A quick update ref the above. I found it easier to align every thing if I fitted the lca to the trailing arm first.Secondly, and not sure about other brands, but if you buy Skunk 2 and you have the mg arb & links, you will need a bolt which has a 1.25 thread to connect to the lca.Any questions, please let me know. Quote Link to comment Share on other sites More sharing options...
