kenny_tmt Posted May 31, 2013 Share Posted May 31, 2013 So I'm searching for a subframe, but I don't know which one I have to buy ? Does the EG subframe fit the mc2/mb6 ? This is a subframe: Quote Link to comment Share on other sites More sharing options...
KieranEG6 Posted June 4, 2013 Share Posted June 4, 2013 Thats an ASR subframe/Lower chassis brace, not an actual frame as such. Just a big plate that bolts on top of the rear frame. Is used (advised needed) on EGs and Non Type R EK/EJs so they can fit bigger DC2 or EK9 rear anti roll bars, as the rear frame is considered too weak for the higher stress bigger ARB's off Type R's. Has been seen to crack on EKs and EJ9's. Although the bottom arm mounting point should line up (but Im not sure of that) as the EG rear arms fit, you would need to fabricate the rest of the bolting support as it uses the stock ARB chassis holes to mount on, then the ARB mounts on top of the new brace.In thoery If you could fit this brace to an MB/MC then you would be able to run the likes of DC2 rear ARB or the ASR bigger adjustable one. Quote Link to comment Share on other sites More sharing options...
kenny_tmt Posted June 5, 2013 Author Share Posted June 5, 2013 KieranEG6 said: Thats an ASR subframe/Lower chassis brace, not an actual frame as such. Just a big plate that bolts on top of the rear frame. Is used (advised needed) on EGs and Non Type R EK/EJs so they can fit bigger DC2 or EK9 rear anti roll bars, as the rear frame is considered too weak for the higher stress bigger ARB's off Type R's. Has been seen to crack on EKs and EJ9's. Although the bottom arm mounting point should line up (but Im not sure of that) as the EG rear arms fit, you would need to fabricate the rest of the bolting support as it uses the stock ARB chassis holes to mount on, then the ARB mounts on top of the new brace.In thoery If you could fit this brace to an MB/MC then you would be able to run the likes of DC2 rear ARB or the ASR bigger adjustable one.Thx! Quote Link to comment Share on other sites More sharing options...
