Guest Posted August 7, 2013 Share Posted August 7, 2013 On 8/7/2013 at 11:23 AM, UnicyclingTom said: They do come up, quite a rare oem option. Worth asking in the wanted section for one, or asking people breaking decks if they have one.I'll be keeping an eye out, if not something custom will be fashioned! Quote Link to comment Share on other sites More sharing options...
HONDACIVIC Posted August 8, 2013 Share Posted August 8, 2013 does your car handling improve by havnig camber on the rear wheels or isit best to get them alligned and get them straight Quote Link to comment Share on other sites More sharing options...
Krzys Posted August 9, 2013 Share Posted August 9, 2013 On 8/6/2013 at 2:45 PM, Sleeper_ said: Depends how hard you corner, Tyres "Swish" from side to side (like water) under heavy steering. The more camber you got the more inside wear although if you corner hard you get swish which will move toward the angle of cornering thus flattening out under higher cornering loads I used this as part of my dissertation research material during my Degree;http://www.motoiq.com/MagazineArticles/ID/1781/PageID/2539/The-Ultimate-Guide-to-Suspension-and-Handling-Part-Six-Adding-Negative-Camber.aspxYeah I know they do level out a bit, but didn't know about the 'swish' part, everyday is a school day! Quote Link to comment Share on other sites More sharing options...
