Robban Posted January 21, 2010 Share Posted January 21, 2010 Hi.I am a new member from Sweden and I have just bought a Mb6 I have a problem with the cel. It doesn't light up at all. I have found out that my ecu (p9k) is the problem. Someone has probably burnt the ecu when they tried to remove the cel. I have bought a p28 instead and now I want to know how to install it in my car. I have read on other sites that you can bridge pin a17 and a19 to get the IAB's working and also bridge pin a6 with d4 to get the vtec working. Can someone here confirm that this is correct? If so, how do I bridge these pins the correct way? Do I have to solder inside the ecu? And where do I do the soldering in the ecu?Looking forward to hear your thoughts! Link to comment Share on other sites More sharing options...
oemeg4UK Posted January 31, 2010 Share Posted January 31, 2010 i have the same problem at the moment, could anyone advise me please..also can anyone provide a chip for a socketed p28 to run a b18>?? many thanks tom Link to comment Share on other sites More sharing options...
