LuÃs Posted January 17, 2014 Share Posted January 17, 2014 Hi guys.Today as i said i start to mount my new tail lights but in one of them i have this cap: I don´t know how to remove it does anyone know?It has a bit of plastic attached on the inside too. Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 17, 2014 Share Posted January 17, 2014 It should come out easily with some force or help from a drill and file? Quote Link to comment Share on other sites More sharing options...
LuÃs Posted January 17, 2014 Author Share Posted January 17, 2014 Thank you krzysYes but it only goes to the inside of the tail light, then how do i take it out? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 17, 2014 Share Posted January 17, 2014 I haven't done it myself but my thinking is if you maybe put a hole into it with a drill then you can get something in with a hook maybe to pull it out? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 17, 2014 Share Posted January 17, 2014 Taken from the How JDM your lights thread, hope this makes sense! Passenger Side1- To remove the rear light lens, open the boot and pull back the carpet behind light. there should be a push clip remove this with a flat blade screw driver and pull back carpet then you will see the 4 x 8mm fixing nuts undo these , then unclip the multi plug that the loom plugs into this is a push clip with a little tab push down on the tab to release. Now the lens cluster will pull off nice n easy. Done! 2-Ok there there is no rear fog light on the passenger side however honda kindly left us the hole for the bulb holder to go but its has a plastic plug in it and its a moulded item so cant just pull it off so get yer drill out and drill round the edge of it till you have a hole for the bulb holder to sit in! Done before and after the drilling use a file to tidy up edges 1 Quote Link to comment Share on other sites More sharing options...
LuÃs Posted January 17, 2014 Author Share Posted January 17, 2014 Thank you Krzys i was looking and that is it because my new tailligts came from the uk and that is the hole where the fog light gets in and the portuguese tail lights it´s on the other side that is why it has a cap on it and my other doesn´t have the cap.Now i´m going to drill it and later on i will post an how to guide on how to mount new tail lights 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 17, 2014 Share Posted January 17, 2014 Thank you Krzys i was looking and that is it because my new tailligts came from the uk and that is the hole where the fog light gets in and the portuguese tail lights it´s on the other side that is why it has a cap on it and my other doesn´t have the cap.Now i´m going to drill it and later on i will post an how to guide on how to mount new tail lights Glad I could help! Quote Link to comment Share on other sites More sharing options...
