Chris_M Posted January 7, 2015 Share Posted January 7, 2015 Recently had my clutch changed and everything was going good until a few days later i noticed the car was harder to get into gear in the mornings, I usually leave the car running for about 5-10 mins before leaving for work but when i try to put the car into any gear it is very stiff and requires a bit of force im just wondering is it related to the clutch being changed recently or is there something else involved?1.5 Civic mb3 126k on the clock Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted January 7, 2015 Share Posted January 7, 2015 Hi there:) where is the biting point in relation to pedal travel as it could be a simple bleed down job or it could be master or slave issue have a look around them for leaks Quote Link to comment Share on other sites More sharing options...
Chris_M Posted January 10, 2015 Author Share Posted January 10, 2015 The bitting point was very high until i got the clutch replaced, its now sitting alot lower and feels more normal,ive just had a look under the bonnet and cant see any signs of a leak although there has been times ive been washing the car and noticed an oil slick in the water on the ground Quote Link to comment Share on other sites More sharing options...
