mobz91 Posted March 25, 2010 Share Posted March 25, 2010 was looking at these blue lights for the civic on ebay.Any one have any times on which would fit for that blue hid effecthttp://cgi.ebay.co.uk/ICE-BLUE-Xenon-H4 ... 3efa188dba will these fit Link to comment Share on other sites More sharing options...
jalesi2001 Posted March 25, 2010 Share Posted March 25, 2010 Yep, they will fit mate....good price too!! Link to comment Share on other sites More sharing options...
mobz91 Posted March 26, 2010 Author Share Posted March 26, 2010 Thanks mate.they should really look good.i am skint so i have to go for these hid look lol.do you know how to change the bulbs mate? Link to comment Share on other sites More sharing options...
jalesi2001 Posted March 28, 2010 Share Posted March 28, 2010 For the headlights, unplug the black plug on the back of the headlight bulb, then remove the black rubber cover. This should then allow you to see the bulb sitting in the back of the headlight, being held in by a metal clip. Unclip that, (it will unclip on one of its sides) and then remove the bulb. Make sure you dont touch the glass of your new bulb, then fit it into the headlight, making sure that the 3 metal tabs on the bulb are fitting into the headlight correctly, you should have two facing downwards, and one at the top, kinda like an upside down Y. Then re-fit the metal clip, the rubber cover and finally the plug. Then turn on your lights and check they work!! Its easier to explain when you are looking at it so when you come to change them it should make sense!! Another tip, do one side at a time so if you get stuck, you can check the other side!! As for the side lights, just below the headlight bulb, you will see a plug sticking into the headlight, twist that 45 degrees to release, then simply pull out the old side light bulb, and replace it with your new ones, again, twist it 45 degrees in the opposite direction to secure.Job's a good'un. Link to comment Share on other sites More sharing options...
mobz91 Posted March 29, 2010 Author Share Posted March 29, 2010 how do i get access to the headlight section? Link to comment Share on other sites More sharing options...
