Guest Posted March 25, 2010 Share Posted March 25, 2010 I have got a 96 spec jdm itr engine, loom and ecu.will the itr engine loom plug into my car loom and will the ecu fit or will i need a converstion harness? Link to comment Share on other sites More sharing options...
jalesi2001 Posted March 25, 2010 Share Posted March 25, 2010 I have no idea.....but fair play, a teg engine in our 'm's will be sweet....!!!!!!! Link to comment Share on other sites More sharing options...
civicturbo79 Posted March 26, 2010 Share Posted March 26, 2010 If you have the loom the best way to tell if it will fit ,is to compare the plugs on the left hand and right hand sides of the engine there is 2 on one side and 3 on the other , rich . Link to comment Share on other sites More sharing options...
stubrun Posted March 26, 2010 Share Posted March 26, 2010 i think you mighht have to add a wire for the knock sensor mate as jdm motors have them on, if you had a uk ecu it wouldnt look for it. it will drop straight in, you may need either the itr/eg vti shifter linkages. what year is your car, you may need an obd harness for your ecu plugs. stuart Link to comment Share on other sites More sharing options...
