jalesi2001 Posted April 5, 2010 Share Posted April 5, 2010 Yeah, the 5 pin should plug into a diagnostic reader machine if you have one with the correct software, you can also bridge 2 pins of the 5 pin plug if you want to read the ABS fault codes, so you are both right!! Link to comment Share on other sites More sharing options...
supermike Posted April 6, 2010 Author Share Posted April 6, 2010 Iv ordered an adaptor cable now, hopefully my scanner will read the codes.... Link to comment Share on other sites More sharing options...
noodels Posted March 1, 2013 Share Posted March 1, 2013 Yeah, the 5 pin should plug into a diagnostic reader machine if you have one with the correct software, you can also bridge 2 pins of the 5 pin plug if you want to read the ABS fault codes, so you are both right!! quote: you can also bridge 2 pins of the 5 pin plug if you want to read the ABS fault codes Q:^^^^whats the wire colours for abs diagonistic bridge plzz >>perhaps light blue and ?+turned ignition oft 20 and 30 times to reset, and light still stayed on Link to comment Share on other sites More sharing options...
noodels Posted March 2, 2013 Share Posted March 2, 2013 anybody Link to comment Share on other sites More sharing options...
