mobz91 Posted April 2, 2010 Share Posted April 2, 2010 Hello, i ordered some headlight bulbs with the blue xneon effect.was wondering how do i change them.iv also got some blue side lights? Link to comment Share on other sites More sharing options...
jalesi2001 Posted April 5, 2010 Share Posted April 5, 2010 For the headlights, unplug the black plug on the back of the headlight bulb, then remove the black rubber cover. This should then allow you to see the bulb sitting in the back of the headlight, being held in by a metal clip. Unclip that, (it will unclip on one of its sides) and then remove the bulb. Make sure you dont touch the glass of your new bulb, then fit it into the headlight, making sure that the 3 metal tabs on the bulb are fitting into the headlight correctly, you should have two facing downwards, and one at the top, kinda like an upside down Y. Then re-fit the metal clip, the rubber cover and finally the plug. Then turn on your lights and check they work!! Its easier to explain when you are looking at it so when you come to change them it should make sense!! Another tip, do one side at a time so if you get stuck, you can check the other side!! Link to comment Share on other sites More sharing options...
mobz91 Posted April 7, 2010 Author Share Posted April 7, 2010 all done.looks fab in the night.thanks guys Link to comment Share on other sites More sharing options...
