MB1 D16Y3 Disc brake conversion - upgrade to MB6
kkkostas
fronts yes!! what you need to do is get yourself some MG ZS 2.5l front discs from my memory.
they are 4x100. use the MB6 carriers etc I think, and there is a small step on the inside of the carrier that needs grinding off.
if you want to swap hubs etc over it should all go on, but the pcd is 4x114.3 rather than 4x100 which you'll probably be running
