As per the title, my mb6 brakes have been quite bad recently. Noticed it most after spending a week driving a different car and then got back in the civic to notice my brake pedal goes almost all the way down before I feel the brakes taking effect.
I have evenly bled the system (twice) so confident there are no air bubbles in the system.
Also no brake fluid loss, so fairly sure it's not leaking anywhere.
thinking either the servo or master cylinder?
having had a look around, I can't seem to find replacement parts anywhere? Are they all the same for all engine variants? eBay currently has an assembly from a 1.4, just not sure if that's the same as what was fitted to the vti-s (1.8).
Obv do do not want to spend loads on sparkly new parts, so good second hand will do, or even rebuild kits if they are available. Just not found anywhere that has either available.
anyone confirm my susp**sion on either the servo / master cylinder and also recommend places to buy new bits from?
Question
Shaddow
Hi,
thanks
2 answers to this question
