nellymon Posted May 3, 2010 Share Posted May 3, 2010 hi lads new to this site.. just joined.. i bought a p73ecu out of dc2 integra and have the wire harness aswell but when i put it in engine management light is on and wont hit vetec. i was told it should work by someone but then was told it has to be hardwired to the engine.. any ideas lads as you can see i no very little about it!! Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 3, 2010 Share Posted May 3, 2010 Ecu's are a mine field mate , At the end of the day what you need is a standard ecu with a piggy back ecu so you get no lights on , or something like a p28 ecu with hondata s300 or chrome something along those lines as you can turn the sensors and lights on and off as you see fit . Plus the car is mapped to what mods you have , there is no cheap way to fit an ecu and map it , the cheapest you will be looking around £400 for an ecu and mapping . Or get a vafc 2 you can do some very small tunning on that to get the most out of exhaust and filters , again needs to be set up on a rolling road . i bet the car is better on the standard ecu i would take out the one you have . Rich. Link to comment Share on other sites More sharing options...
nellymon Posted May 7, 2010 Author Share Posted May 7, 2010 cheers man for that... wil do that.. i need to get a full polybush kit for it but cant find anywher that does them .. any ideas?? Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 8, 2010 Share Posted May 8, 2010 Its hard to get anything like that for a mb6 mate , any other honda there is loads to choose from , Rich. Link to comment Share on other sites More sharing options...
jalesi2001 Posted May 8, 2010 Share Posted May 8, 2010 Give funkypower a call, they may be able to help you on your quest!!! http://www.funkypower.co.uk/catalogue.p ... HINGS&man= Link to comment Share on other sites More sharing options...
adeel Posted August 5, 2010 Share Posted August 5, 2010 iv heard that the si- R p72 ecu can fit Mb6 with a few mods and its 180bhp standrd ?? Link to comment Share on other sites More sharing options...
cal Posted November 5, 2010 Share Posted November 5, 2010 sir (b18c have a higher compression ratio than a b18c4. the ecu helps a little though. also far as i know the siR has a knock sensor too so you will need one also to run the P72 Link to comment Share on other sites More sharing options...
