  • 0
ramy
Abs light on but cant pull codes no power to blue lead
Hi guys please help my deck has throw on the abs and brake light,   they reset over night then after a miles or so they come back on,,  had her in garage and they cant contact computer they also tired the jumper on the 5 pin blue glug but didnt happen,,,,,,  they think no power is going to lead,   checked fuses and all ok,,   please please help cant face sending her to the scrapes yard
Many thanks
Garry (ramy)
Share this post
Link to post
1 answer to this question
  • 0
Is it an old data link or an obd2?
When I brought my mc2 the abs didn't work, mine has a data link connecter, I found a 0bd2 conversion lead on the net an got it plugged in at local garage. Had 1 dead sensor on front and intermittent on the rear.
When I got second hand ones an replaced it was still no good, so I got the car in the air again an head a wire brush on the abs ring on the shaft to clean it up, then took the car for a spin an locked the breaks, the abs then started working
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
Answer this question...
  Only 75 emoticons maximum are allowed.
