Guest Posted July 21, 2010 Share Posted July 21, 2010 I've done a few motorway journeys lately and there has been an intermittant droan when goingt at 70+.It doesn't happen too often or last for long, I'm sure it's coming from the front right.I don't think it's a wheel bearing as it doesn't whine, could it be a dry CV on the driveshaft? There doesn't appear to be any thing leaking so I'm a bit lost as to what it is.Any ideas? Link to comment Share on other sites More sharing options...
Spadooky Posted July 21, 2010 Share Posted July 21, 2010 Have you tried cranking your head unit up, not very constructive i know but it works! Link to comment Share on other sites More sharing options...
SteveMB6 Posted July 21, 2010 Share Posted July 21, 2010 If you are definate its not the wheel bearing it could be the drive shaft, as they go on the inner joint.Mine had a noise before mine went, but it was more of a rough noise rather than a drown. Also when you accelerate hard and you get a bit of a judder/vibration, this can be a sign of driveshaft wear.Failing that it could just be a window not shut properly at the rear or the sunroof Link to comment Share on other sites More sharing options...
Guest Posted July 21, 2010 Share Posted July 21, 2010 It's all closed up so no issues there (shutting the window did cure a squeal the other week!)I haven't had a change to jack the car up and check for play in the bearings yet so it still might be that. They normally make more of a grinding sound when they go though don’t they?Plus I would assume it would be all of the time?Oh and no odd vibrations etc to report. Link to comment Share on other sites More sharing options...
SteveMB6 Posted July 21, 2010 Share Posted July 21, 2010 wheel bearing usually make a whirling noise that gets louder and higher pitched the faster your wheels go round.good luck with it. Link to comment Share on other sites More sharing options...
james Posted July 21, 2010 Share Posted July 21, 2010 could it be a gear box bearing Link to comment Share on other sites More sharing options...
