edwardm Posted November 4, 2010 Share Posted November 4, 2010 Will it cause damage to the engine lowering the VTEC?Are there many people that do it to the MB6?Is it cheap and easy to fit?Thanks Link to comment Share on other sites More sharing options...
civicturbo79 Posted November 4, 2010 Share Posted November 4, 2010 It will not damage the engine . i have a apexi vafc 2 on my mb6 turbo but that was a raise the vtec from 4500 rpm (standard on the mb6) to 5500 to come on just after the turbo cut in . you will be looking to pay £100-£150 for one and there is about 10 wires to tag into the ecu loom . you will need to know what you are doing and you will need a pinout for the p9k mb6 ecu to get the wires right .they are no good really on the mb6 for use with the vtec as its so low already on the mb6 but the controller also does adjust the air fuel ratio's in 500 rpm stages so if you have some mods you can make the best out of them , but to do that you will need to pay a mapper an hour on the dyno to get the best out of it . Rich. Link to comment Share on other sites More sharing options...
Touge_battle Posted November 4, 2010 Share Posted November 4, 2010 does the inlet flaps runners not open up at 4500 and then vtec at 5900 in all mb6 stock,? Link to comment Share on other sites More sharing options...
civicturbo79 Posted November 4, 2010 Share Posted November 4, 2010 This has been cover so may time on this forum i can 100 % say its vtec at 4500 rpm controlled by the ecu and the inlet flaps open at 6000 rpm by vaccum . The b18c4 is the only honda engine with this set up . Rich. Link to comment Share on other sites More sharing options...
edwardm Posted November 5, 2010 Author Share Posted November 5, 2010 I have heard its 2 stage.My mate said similar to rich, but all i can say regardless is that i only feel something around 5,800 rpm. I don't deny it comes in at 4,500 rpm, but for some reason you feel it at 5,800 rpm (ish). Link to comment Share on other sites More sharing options...
bepilot Posted November 5, 2010 Share Posted November 5, 2010 don't depend on your feelings, I was like you when I started with my MC2.See me here playing with my vtec-light, I'll have to rerecord it as you can't really hear the IABs coming in at 6000... distributor has been reset too since... this resumes it all (B18C1 similar to our B18C4s)http://www.team-integra.net/sections/articles/showarticle.asp?ArticleID=246 Link to comment Share on other sites More sharing options...
johngreen537 Posted November 5, 2010 Share Posted November 5, 2010 Definitely 4500 for VTEC!My VTEC light comes on when the VTEC signal is received, 100% 4500 (if over 30% throttle!)Inlet runners / butterflies begin to open at 5800 and are usually completely open at 6000! Link to comment Share on other sites More sharing options...
cal Posted November 5, 2010 Share Posted November 5, 2010 dont really see the point of having a vtec controller.your moving the point but your not altering the fuel/air mix.if you want to move the vtec point do it properly with a remap Link to comment Share on other sites More sharing options...
civicturbo79 Posted November 5, 2010 Share Posted November 5, 2010 The vafc 2 does can change the air/fuel ratios in 500 rpm stages . Rich. Link to comment Share on other sites More sharing options...
johngreen537 Posted November 5, 2010 Share Posted November 5, 2010 dont really see the point of having a vtec controller.your moving the point but your not altering the fuel/air mix.if you want to move the vtec point do it properly with a remapVAFC= VTEC & Air & Fuel Controller Link to comment Share on other sites More sharing options...
