Rear Tyre wear.
OldManBlue
Looking for a little bit of advice or help for a newbie.
Got an X reg Mb2 sport and as it was my aunts I know all history since the day she got it from new. Well looked after and full honda history with gearbox, steering rack and air con compressor changed under warranty. My problem is that it had 4 new tyres last year and having checked it over realised that both rears are worn bald on insides. car does look as if rear wheels camber out too much. my question is " Is this gonna be expensive or is it something i can fix?". Any help appreciated.
wont be camber, camber does not kill tyres if the toe settings are correct,
toe out causes inner edge wear
as stated above get a full 4 wheel alinement done and your problem should go away,getting an alinement does not mean take it to quickfit for a tracking, tracking is no use at all as all it does is set the front wheels paralel and is set of the rears, so if the rears are wonky then no matter how much you track it it will always be wrong
4 wheel alinment measures all geometery and sets from reference points on the chassis
