rebuild
lacos
As in new piston rings bearings gaskets belts and so on . including labour as well ? Its not as easy as that what is wrong with the engine now ? if it burns oil you will have to have the bores check and if it needs reboring that is going to cost you £400 for pistons allow + having the bloke bored another £80 there . Rich.
2nd john on that one you could get a second hand unit but end up with the same problem but on the other hand it could be ok . one thing it will be alot cheaper , if yours is burning alot of oil i would say you have a bore problem and therefore you have £400 worth of pistons to buy just for a start . Rich.
