nathan123487 Posted March 12, 2011 Share Posted March 12, 2011 will i need to change the wheel bearing at the same time ( apparently on mk3 golfs the discs on the back make up the hub or something ? or hold the bearing in place? ) is civics the same? and whats the procedure ? i dont have a piston winder so will it be possible without one or shall i get a mechanic to do it for me?cheers chaps Link to comment Share on other sites More sharing options...
philgor Posted March 12, 2011 Share Posted March 12, 2011 just done rear disk'n'pad + caliper, on mineremove wheel,slacken off disk securing screw's (had to drill mine out)remove cailiper+carrier from back of hubremove the disk (hammer if disks arn't being reused)thats the disk+pads removedremove bearing cap (hammer+chisel) around the cap between bearing and capuse breaker bar/buzz gun/windy gun, to undo bearing nut (can't remember size, 27mm/30mm/32mm)bearing should just slide offREMEMBER TO USE THE HAMMER AND CHISEL TO SECURE THE HUB NUT TO THE HUB WHEN YOU HAVE TOUQUED IT UPBTW, i took the bearings off to paint back plates on minejust reread the o.p message, the bearing is an seperate item to the disk. Link to comment Share on other sites More sharing options...
nathan123487 Posted March 13, 2011 Author Share Posted March 13, 2011 cheers for that i will be doing it either this week or next week just wasnt sure if the bearings needed to come out or not Link to comment Share on other sites More sharing options...
johngreen537 Posted March 13, 2011 Share Posted March 13, 2011 You can get away without a piston winder too mate. Just get the largest flat head driver you can find, use the side of the head, not the actual flat head part, and you can wind them in provided they in good condition!Winders ain't cheap, £30ish, I've got one, pay for postage both ways and I'll post it to you if you need it.90% of the time though, I don't bother with it!Large flat head usually does the trick, only use winder in bad situations And remember to turn it anti clockwise! Link to comment Share on other sites More sharing options...
nathan123487 Posted March 13, 2011 Author Share Posted March 13, 2011 cheers john.. i might go get the discs today (if theyre 25 pound... i think they was) as thats the last of the money i got left till payday (start a job tommorow ) i cant remember if they said they was £25 or £37 hahaha ill prob pop down there later and have a see tho Link to comment Share on other sites More sharing options...
