vtivtec170 Posted May 22, 2011 Share Posted May 22, 2011 hi i have just read thisviewtopic.php?f=62&t=46&p=33453&hilit=ecu+reset#p33453but near the bottom it says does not apply to M'sso what is the reset procedure for M'sthanks Link to comment Share on other sites More sharing options...
johngreen537 Posted May 22, 2011 Share Posted May 22, 2011 Pop out fuse number 6 labelled "backup" for an hour mate.Let it idle to normal temp, then rag the crap out of it for a while! Link to comment Share on other sites More sharing options...
King Posted May 22, 2011 Share Posted May 22, 2011 What about if your 'backup' fuse is 'missing'? Do we actually need one as i dont have one! Link to comment Share on other sites More sharing options...
vtivtec170 Posted May 22, 2011 Author Share Posted May 22, 2011 johngreen537 said: Pop out fuse number 6 labelled "backup" for an hour mate.Let it idle to normal temp, then rag the crap out of it for a while!and leave fuse labelled 'ecu' in there?no problem Link to comment Share on other sites More sharing options...
Aky Posted May 22, 2011 Share Posted May 22, 2011 Warm car up to normal tempTurn car off and take ECU and backup fuse out for 10minFit back in and idle car for 10min (don't rev)Switch car off, start back up and drive Link to comment Share on other sites More sharing options...
knight Posted May 22, 2011 Share Posted May 22, 2011 ECU Reset,,,After much Googling about resetting the ECU a variety of answers come up. None which seem to fully apply to the MB6 as usual Some of the literature says that Honda ECU's have a fuse that says "back up" or a fuse that says "ECU" and you should remove these. The MB6 has both After trial and error today I got a good result from the below.After getting the car warm I shut her down and took out the "ECU fuse 15A" and the "Back Up fuse 7.5A"Left it 10minStarted the car and just left her idling, you're supposed to leave it till it settles down to a smooth idle, [i left it idling for 10min as the fan activates after a certain point and it gives a chance for the fuel trims to include this].Shut the car down and started it back up straight away. [This is supposed to save the new fuel trim settings]. Link to comment Share on other sites More sharing options...
belfastlad123 Posted May 24, 2011 Share Posted May 24, 2011 why do you have to do this ?? Link to comment Share on other sites More sharing options...
knight Posted May 24, 2011 Share Posted May 24, 2011 sorce,,, http://www.team-integra.net/forum/blogs ... t-ecu.htmlThe ECU's of today are very sophisticated computer chips that monitor all the data recorded by the various sensors in the engine. Not only do they monitor the engine, they can also make changes based on the data that was recorded to keep the engine running at it's maximum possible efficiency. When a modification is done on one of our cars, the program that the ECU was running ends up conflicting with what is now going on in the engine. This can cause problems especially at idle when the engine hangs in the dangerously low RPMs or just stalls out. So instead of waiting for the ECU to adjust itself, you might need to reset it manually. Link to comment Share on other sites More sharing options...
belfastlad123 Posted May 24, 2011 Share Posted May 24, 2011 aww right get you know lol what kind of mods would you have to do this after.could it make the car worse ?? Link to comment Share on other sites More sharing options...
knight Posted May 24, 2011 Share Posted May 24, 2011 belfastlad123 said: aww right get you know lol what kind of mods would you have to do this after.could it make the car worse ??From my project thread,,,, knight said: Thanks to TontVTi for this info,,, 1"£££$££"!! ECU Reset,,,After much Googling about resetting the ECU a variety of answers come up. None which seem to fully apply to the MB6 as usual Some of the literature says that Honda ECU's have a fuse that says "back up" or a fuse that says "ECU" and you should remove these. The MB6 has both After trial and error today I got a good result from the below.After getting the car warm I shut her down and took out the "ECU fuse 15A" and the "Back Up fuse 7.5A"Left it 10minStarted the car and just left her idling, you're supposed to leave it till it settles down to a smooth idle, [i left it idling for 10min as the fan activates after a certain point and it gives a chance for the fuel trims to include this].Shut the car down and started it back up straight away. [This is supposed to save the new fuel trim settings].---------------------------------------------------------------------------------------------------------------------------------------Right i was a bit skeptical about the results of doing this proberly the first time this has been done to my VTi since all the mods were done! (& since the mods it has been feeling slower getting flat spots etc etc,,,But i can not belive the difference it has made (almost unbelievable) i can't stress that enough!!! all my flat spots are gone, quicker acceleration, smoother all round, feels completely different in vtec (bit louder) like driving a different car! I'm in shock lol!!! I would recommend everyone to do this! Link to comment Share on other sites More sharing options...
