shebabby Posted June 5, 2011 Share Posted June 5, 2011 hi peeps iv had my deck for some years now and have been through 3 distributors so far ?when i say distributor i mean the pcm inside the dizzy .the last two was that so im presuming the 3rd one that went today is going to be the same .so just asking if anyones had the same problem ?cheers . Link to comment Share on other sites More sharing options...
noodels Posted June 6, 2011 Share Posted June 6, 2011 you need to use white heat sink greese for heat disapation get it from electronics shop !!http://www.google.co.uk/products/catalo ... DEQ8wIwAg#just an idea Link to comment Share on other sites More sharing options...
johngreen537 Posted June 6, 2011 Share Posted June 6, 2011 Did you reaplce previous one with new or scrappy parts mate?B series dizzy's are prone to dying, the 1st one going is inevitable eventually, the 2nd one, depends weather you bough new or used... If it's used, then it's just a gamble as with all used parts! Link to comment Share on other sites More sharing options...
shebabby Posted June 6, 2011 Author Share Posted June 6, 2011 Did you reaplce previous one with new or scrappy parts mate?B series dizzy's are prone to dying, the 1st one going is inevitable eventually, the 2nd one, depends weather you bough new or used... If it's used, then it's just a gamble as with all used parts! sounds good to me .there all used (second hand) parts . i nealy hit the floor when i priced a new one up also tried to get a new pcm (power controle module) but cant seem to find a supplyer . Link to comment Share on other sites More sharing options...
shebabby Posted June 6, 2011 Author Share Posted June 6, 2011 you need to use white heat sink greese for heat disapation get it from electronics shop !!http://www.google.co.uk/products/catalo ... DEQ8wIwAg#just an idea good idea but its a sealed ceramic unit mate ! Link to comment Share on other sites More sharing options...
noodels Posted June 6, 2011 Share Posted June 6, 2011 pcm =ecu do you mean coil or igniter ?how to mate tells you about grease ect at the bottom http://techauto.awardspace.com/ignition.html Link to comment Share on other sites More sharing options...
shebabby Posted June 6, 2011 Author Share Posted June 6, 2011 pcm =ecu do you mean coil or igniter ?how to mate tells you about grease ect at the bottom http://techauto.awardspace.com/ignition.htmlmy mistake i mean the icm (ignition controle module) .thanks for the link tho matey Link to comment Share on other sites More sharing options...
