best place to put axle stands.
KiNK43
Yes mate. Or If you are worried, and you hava jack that will lift the rear end high enough, sitck them on the jack points on the sills!
You'll notice on your stands a little cut out section on the V bit, which is specifically designed for this! I had my EP3 on stands for 2 days on the sills waiting for drop links to turn up as I had to remove the LCA's to put on the subframe strengthener!
You can see them in the bottom corners of this pic:
7f%20(5).jpg?psid=1
You just need a jack that will lift the car high enough to get the stands under the sills!
+1 sill jacking points :idea: jack up there if you here crunching sound think of another place quickly :shock:
