Brakes ... Help
Nav
  • Replies 25
On the drive shaft there is a castlelated type ring for the abs these corrode and break causing a bigger gap so the abs gets confused and starts kicking back it can also create a hard pedal.
If the servo was faulty it would cause a hard pedal with poor brake effort
If pedal goes to the floor with poor pedal means a leak some where if no leaks visible the on could be master cylinder internal seal s split and allowing fluid to go past so poor pressure =poor pedal on the floor we had this on a corsa last week!!
Can do servo and cylinder 25 plus postage
nope ABS ring is fine.. so before I start on the car with the brake, shall I just change the brake cylinder or need to change both (servo and cylinder)... i am not sure how hard is this to do...hmm time to consult the trusty Haynes manual...
I would start with the cylinder as if it was the servo the brake go rock hard most of the time . Rich.
Cheers Rich... was hoping some one would say that.. well i know how i am going to spend this weekend...:)
