MB2 speaker upgrade
lokkochaa
Hiya
Has anyone upgraded the speakers on an MB2? Had it at the garage the other day and the door panel was off for something else and checked out speakers at the same time.
16cm/6" in size but they are really narrow doors.
Anyone got any recommendations to upgrade the stock paper plates?
Cheers
If you are upgrading the speakers make an MDF baffle rather than use the plastic ones. You will fit 6.5" speakers easilly and magnet size isnt much of a problem.
Ive got these mids in my doors only using 18mm mdf baffle:
images?q=tbn:ANd9GcTROGQSEjXnqcTrRABuhMEHM4PmAhz2DT_SOHZ-GD-8xtqmbj-pVg
Hi Guys
Thanks for the replies.
When making an 18mm MDF baffle with the screws go in at an angle as they are slightly wider?
Im going to be making an MDF stealth shelf for the rear of the car so should have some MDF spare at the end
