leejt1979 Posted September 9, 2011 Share Posted September 9, 2011 hey guys... the MB6 is going through a naughty stage... it now has an idle problem. Seems to lose revs at every junction or when depressing the clutch, does not actually cut out but comes close every time!!! i have a little mis-fire hesitation issue which i previously posted about and have ordered a new lambda sensor to sort that but was wondering if this other issue could be tied in! any ideas guys??? Link to comment Share on other sites More sharing options...
Didjeridave Posted September 9, 2011 Share Posted September 9, 2011 If you've already ordered the sensor, this may be a little late, but you can test the old one by connecting it to a voltmeter & placing it in a blowtorch flame. If the voltage rises to over half a volt, the sensor is probably fine. Misfire would definitely be more obvious on idle & as high voltage components get old they can gradually deteriorate before they completely fail. One thing to check is whether spraying WD40 on the leads makes the problem go away - if it does, you need a new set. You can also try running the engine with each lead removed one after the other to see if you can isolate a particular cylinder where the misfire occurs. If you can, then the problem is the dizzy or the lead/plug for that cylinder. If it's not dependent upon cylinder, it could be the coil. Link to comment Share on other sites More sharing options...
leejt1979 Posted September 10, 2011 Author Share Posted September 10, 2011 it does not miss all the time only on light throttle! i can accelerate through it! but the idle is not a miss... just drops right done low Link to comment Share on other sites More sharing options...
Didjeridave Posted September 10, 2011 Share Posted September 10, 2011 Any difference between the engine being cold or normal operating temp? Link to comment Share on other sites More sharing options...
leejt1979 Posted September 11, 2011 Author Share Posted September 11, 2011 no mate... happens at any point!! Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 11, 2011 Share Posted September 11, 2011 o2 sensor , as once you are on full throttle well over 70% anyway the car runs off the map not the o2 sensor . so thats why you can drive through it . Rich. Link to comment Share on other sites More sharing options...
leejt1979 Posted September 12, 2011 Author Share Posted September 12, 2011 thanks to all... O2 sensor being fitted friday!!! cant bloody wait!!! Link to comment Share on other sites More sharing options...
leejt1979 Posted September 18, 2011 Author Share Posted September 18, 2011 It's sorted!!! fitted the lambda which sorted the hesitation and cleaned out the idle control valve (which was full of carbon) runs/idles perfectly once again.. fast as feck once again!! Carried out a smoke test to see if i had any air leaks and found to be the best sealed engine the mechanic had tested!! very happy boy again!!! Link to comment Share on other sites More sharing options...
