rear anti roll bar
Guest kev21
  • Replies 30
  • 3 weeks later...
  • 1 month later...
  • 9 months later...
Hi,
I know this is an old thread, but I could not find an answer anywhere to my question.
I have found a very cheap rear ARB from a Concerto and I want to know if it will fit on my MB3.
From what I've seen the rear ARB of the MB Civics looks pretty much the same as the 4th gen Civics, Concerto/Rover 200 and Integras from around 1990. The L-shaped mounting brackets seem the same (not mounted to sub-frame), and the Concerto end-links are the same as those on the MG ZS.
Here's a pic of the actual part I'm planning to get.
It's a bit far away from where I live, otherwise I would've just test fitted it. I just want to hear some opinions before I have it sent to me.
Thanks.
Hi,
Thanks.
Hi,
Thanks.
oh boy.. thas a tough one.. it does look exactly the same as the MG ZS ones.. but the thing with these are..its a trail and fit... u might need to do some mods to get it to fit...
Goodluck budd..
Hi,
Thanks.
Goodluck budd..
  • 2 weeks later...
Some feedback on the Concerto ARB. I decided to have it sent after seeing a few more photos.
It did turn out to be a direct fit - mounting holes for the L-brackets, drop links, exhaust clearance.
Only sort of downside is that is only 17 mm thick, it did however improve handling greatly (if you've driven without one and you put it on you really feel it, it does decrease a lot the feeling you're driving barge).
Here it is fitted
