strange noise comes out of the air outlet pipe??
np63om
  • Replies 47
Top Posters In This Topic
  simpo said:
Wat about dry alternator bearings?
Yeah, nice point of view, good guess...
How do i know or test the alternator, do you know?
By the way, it seems to me everything pretty normal, the belt and alternator...
Im just guessing, withou testing anythinhg of it...
Thats reason why I'm asking you, for any kind of test or else is, to get a conclusion...
Regards
  np63om said:
ok, can you be more specific and clearer about it the trick?
This guy in the video uses an 'engine stethoscope' to find where a noise is coming from;
..you can use a hose pipe (or even a short broom handle) as a makeshift engine stethoscope to help you find where the noise on your car is coming from. Like this other guy had done;
Hope that helps! ;)
  shebabby said:
mine sounded a bit like that before i changed my engine !
it also whisled when i accelerated up hills ?
with the sound ov it it realy could be anything .
does it get louder when you rev it ?
Nope, does´t get louder, sounds quite the same...the sound stays exactly like i show it on video!
Now i just note, is becoming louder, month to month i guess, before all of this, the noise dosen´t came out and clearly, i must say it was quite impossibel to hear, must to be near the pipe to hear it.
Now, i just open the hood and you can hear it, loud and clearly, like it was showed on video.
Hope that helps! ;)
I appreciate your concern... i will try some of that i guess...
Regards 1"£££$££"!!
  • 1 year later...
