np63om Posted February 14, 2012 Author Share Posted February 14, 2012 i recon you would hear it more from the timing belt end ?try the peice ov wood trick to determanate it whereabouts ?ok, can you be more specific and clearer about it the trick?My apologize for the inconvenience...Regards Quote Link to comment Share on other sites More sharing options...
np63om Posted February 14, 2012 Author Share Posted February 14, 2012 Wat about dry alternator bearings?Yeah, nice point of view, good guess...How do i know or test the alternator, do you know?By the way, it seems to me everything pretty normal, the belt and alternator...Im just guessing, withou testing anythinhg of it...Thats reason why I'm asking you, for any kind of test or else is, to get a conclusion...Regards Quote Link to comment Share on other sites More sharing options...
np63om Posted February 15, 2012 Author Share Posted February 15, 2012 the timing belt and water pump ar at the other side ov the engine ?Yes, they are!! 1"£££$££"! Quote Link to comment Share on other sites More sharing options...
shebabby Posted February 16, 2012 Share Posted February 16, 2012 mine sounded a bit like that before i changed my engine !it also whisled when i accelerated up hills ?with the sound ov it it realy could be anything .does it get louder when you rev it ? Quote Link to comment Share on other sites More sharing options...
Paul67 Posted February 16, 2012 Share Posted February 16, 2012 ok, can you be more specific and clearer about it the trick?This guy in the video uses an 'engine stethoscope' to find where a noise is coming from; ..you can use a hose pipe (or even a short broom handle) as a makeshift engine stethoscope to help you find where the noise on your car is coming from. Like this other guy had done; Hope that helps! Quote Link to comment Share on other sites More sharing options...
np63om Posted February 16, 2012 Author Share Posted February 16, 2012 mine sounded a bit like that before i changed my engine !it also whisled when i accelerated up hills ?with the sound ov it it realy could be anything .does it get louder when you rev it ?Nope, does´t get louder, sounds quite the same...the sound stays exactly like i show it on video!Now i just note, is becoming louder, month to month i guess, before all of this, the noise dosen´t came out and clearly, i must say it was quite impossibel to hear, must to be near the pipe to hear it.Now, i just open the hood and you can hear it, loud and clearly, like it was showed on video. Quote Link to comment Share on other sites More sharing options...
np63om Posted February 16, 2012 Author Share Posted February 16, 2012 ok, can you be more specific and clearer about it the trick?This guy in the video uses an 'engine stethoscope' to find where a noise is coming from; ..you can use a hose pipe (or even a short broom handle) as a makeshift engine stethoscope to help you find where the noise on your car is coming from. Like this other guy had done; Hope that helps! I appreciate your concern... i will try some of that i guess...Regards 1"£££$££"!! Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted March 5, 2013 Share Posted March 5, 2013 I'm another 10k down the road, still have this noise & have had no problems regarding it in that time; no worse, no better. Did you find any solution to the noise problem? Quote Link to comment Share on other sites More sharing options...
