JaredMac Posted February 21, 2012 Share Posted February 21, 2012 Hi guys, never came across this issue before, hope someone can help!If I start the car from cold and immediately drive off, the temperature needle never rises and as a result, vtec does not engage, however, the heaters get warm as normal.If I start the car, let the needle get up to half then drive off, the needle drops back below the lowest point, however, Vtec still engages and the heaters are still warm. I can then stop the car for a few minutes and the needle rises back up to half again...Bit of an odd one I thought. I changed the thermostat not that long ago as well... Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted February 21, 2012 Share Posted February 21, 2012 I would go for fitting another one , as it sounds faulty to me after you have checked the water that is . Rich. Quote Link to comment Share on other sites More sharing options...
simpo Posted February 21, 2012 Share Posted February 21, 2012 I would go for fitting another one , as it sounds faulty to me after you have checked the water that is . Rich.X2 I take it you fitted it right? Did you put it back the same way it came out Quote Link to comment Share on other sites More sharing options...
