MGZS 180 V6 Spring & Shock...
djbaybeeraver23
Hi Guys,
its getting close to my payday and have got these sat on my ebay list waiting purchase... before i do.. i want to see if i will need any further parts or if theser will just bolt straight in if i get the old shocks and springs removed...
http://www.ebay.co.uk/itm/370579255272?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/MG-ZS-2-5-V6-180-REAR-SHOCKERS-SPRINGS-ROVER-45-400-/230754331543?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35ba07ab97
so with those 2 sets of forks.. will i need ANYTHING more?. for example.. camber arms... toe kits?. bushes?. i want to make sure i have EVERYTHING i need for my garage to fit in one day and one go... so please assist in any way you can.. plus if we have all the parts we need oin one page, i am sure anyone else who wants to do this could simply look at the items on the links and order in one go :).
Thanks
treat as your just fitting a standard set up ,maybe worth trying to loosen things b4 work comences and you are fully commited >>
:idea: but as above the front/ rear lower shocks bolts being main issues to be looked at first banghead.gif1
correct front socket for hub :idea:
what do you mean by the issue with the bolts?. when it comes to the rear i am doing the aformentioned shocks, newe shiny purple lca's, new shiny lower tie bar and shall be betting new bushes all round, so am i going to need new bolts aswell?. if so can someone link me up, and if they are feeling really nice, could you link me up some bush kits worth investing in?
so when it comes to it, its a straight swaop with these or will i need more parts?
Straight swap, noodles is suggesting making sure all bolts will come undone before you do the entire job, i.e. one shock changed other side seized. Rear fork bolts can be a problem. :)
okay i understand better now.. i have a garage doing it for me so if they struggle.. they can sort it, dont wanna do it on axle stands when i have access to ramps..
i have two sets of LCA's that i am choosing between, am swayed more towards the purple..
http://www.ebay.co.uk/itm/230614907207?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/330698568699?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
as long as they both bit togwether then i anm getting them.. also might be tempted to get some D2 toe kits aswell..
  • 2 weeks later...
