fyfie5 Posted May 7, 2012 Share Posted May 7, 2012 im just wondering i have a mb2 and would a mg zs rear arb fit my car? i cant see the attachment points or am i just being stupid? also would a rear tie bar fit mine as i have seen lots of mb6's with rear tie bars but not sure if they would fit my mb2 Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 7, 2012 Share Posted May 7, 2012 MB2 should be the same as MB3. On my MB3 MG ZS arb fitted perfectly with just screwing some bolts The attachement points are there. It's really a easy job. Note spacers should be used to connect the droplinks to the LCA's. Can't remember how mm are mine. Some pics of the arb intstalled: viewtopic.php?f=56&t=9696About the tie bar, the standart MB6 doesn't fit . You have to use tie bar that conects like that:http://www.corsportusa.com/store/catalo ... 4715x8.jpg Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted May 7, 2012 Author Share Posted May 7, 2012 ok cool ill defo look into getting one, so no need to drill any holes or anything? straight fit?and where would i find a tie bar like that? Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 7, 2012 Share Posted May 7, 2012 No drilling necessary, it's a straight fit. And don't forget to buy the front antiroll bar of MB6, it's a must for nonVTI's. With thoose two mods just prepare to be amazed real hard ! I suggest putting them at the same time because with our front arb (18mm I think) the car will became tail happy because of the stiffer rear arb. And tbh there is no need to buy a tie bar or any struts. Thoose two mods are enough and then you can focus on the shocks and springs/coilovers Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted May 7, 2012 Author Share Posted May 7, 2012 cool and the front anti roll bar is that harder to install? could i get a mg zs front arb? ok ill leave the tie bar and i already have coilovers installed Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 7, 2012 Share Posted May 7, 2012 No but let's say a tiny bit harder than the rear one. You have to disconect the catback and the transmission arms to be able to take off the old arb and put on the new one. Unbolt the stock one, put the new one and that's it.According to this thread the MG ZS front arb is the same as MB6 viewtopic.php?f=56&t=5877 Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted May 9, 2012 Share Posted May 9, 2012 I've recently changed the rear ARB on my car and you must get the rear brackets off the MG which the ARB mounts to.As for the front ARB, the MG one looks the same thickness as the Civic but the drop links are a different design, imo they look a to be a better more sturdy design. Quote Link to comment Share on other sites More sharing options...
