np63om Posted May 21, 2012 Share Posted May 21, 2012 hello to you all.have noise when turn the weels... the oil must be changed ?? simple as that or is something more complicaded...The pump is good, no lik and the oil level of Assisted Steering is also normal ?What could it be ?? please help...please.is not all time the noise came but when tunr the well sometimes came up hard noise from the steering weelsHelp please...Regards Quote Link to comment Share on other sites More sharing options...
beastgtir Posted May 21, 2012 Share Posted May 21, 2012 Fluid could be low, the belt could be damaged or cut..or finally, the power steering pump maybe faulty. Quote Link to comment Share on other sites More sharing options...
np63om Posted May 21, 2012 Author Share Posted May 21, 2012 Points to be check, thanks once againI spoke abouta steering weel oil pump, but, i do not know where she is, can you help with it...?When I spoke about it, oil steering pump, i mean there no oil on the ground... and the level is on the rigtht level...Where is the oil pump's of steering weel?Many thanks for all help.Regards Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted May 21, 2012 Share Posted May 21, 2012 Could also be a bottom ball joint worn, or top mount slightly worn. Quote Link to comment Share on other sites More sharing options...
np63om Posted May 21, 2012 Author Share Posted May 21, 2012 You may right, but where it is the oil pump??I will try to change the oil, or look for any kind of oil coming from the pump, but where is the streering oil pump??Regards! Quote Link to comment Share on other sites More sharing options...
np63om Posted May 21, 2012 Author Share Posted May 21, 2012 Could also be a bottom ball joint worn, or top mount slightly worn.My guess goes to the oil pump, the oil is to old must be change, but and the joints is great gess to how do i chek, there is kind of teste to check if is or not??Where is place it the oil pump...??Many thanks for all the help.Regards Quote Link to comment Share on other sites More sharing options...
beastgtir Posted May 21, 2012 Share Posted May 21, 2012 that what it looks like, in the red circle. Quote Link to comment Share on other sites More sharing options...
np63om Posted May 21, 2012 Author Share Posted May 21, 2012 that what it looks like, in the red circle.Thank you for all help and pic!The oil it is now on the level mark! best regards Quote Link to comment Share on other sites More sharing options...
