supermike Posted October 22, 2009 Share Posted October 22, 2009 Yea so my electric windows are really slow and sometimes dont go all the way up, got to put them down a bit then back up again. Any ideas how to sort this out? Link to comment Share on other sites More sharing options...
ShortySco Posted October 22, 2009 Share Posted October 22, 2009 Mine were really, really slow, but did always go right up.I found a tip on here which was to spray the rubber seals around the window with sillicone lubricant spray.My experience was good, did it several months ago and windows still work like new.Only problem i had was smears, but i sprayed the bottom one which probably was a tad foolish. Link to comment Share on other sites More sharing options...
jalesi2001 Posted October 22, 2009 Share Posted October 22, 2009 Ha ha, yeah, a bit!! Just the run channel needs lubing guys, the rubber bit the window slides in!! Put the window all the way down, then just spray the sides, and work the window up and down a few times, should sort the problem!! If it dont work, you may have a twisted/distorted window run channel, or your motor is dying on your window regulator!! Hope this helps! Link to comment Share on other sites More sharing options...
supermike Posted October 22, 2009 Author Share Posted October 22, 2009 Cheers guys will give this a bash! Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 22, 2009 Share Posted October 22, 2009 Your cars suffer with the window regulators getting play in them so with you put the window up it pushs the glass against the rubber (to hard) and the window is slow . i have replace mine 3 times in 5 years with second hand ones its a common fault . but like has been said grease the runners and you can get the window to work . the regulator was a rover part . Rich. Link to comment Share on other sites More sharing options...
supermike Posted October 22, 2009 Author Share Posted October 22, 2009 Rich is there anything you dont know about Hondas? Seem to know quite a bit anyway Link to comment Share on other sites More sharing options...
ShortySco Posted October 22, 2009 Share Posted October 22, 2009 Something i've thought about doing, was replacing the seals as the rubber seems to have aged badly, especially along the bottom, anyone know where to get this for the 'M' or is it just generic stuff you cut to fit, like i've seen in halfords? Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 23, 2009 Share Posted October 23, 2009 Rich is there anything you dont know about Hondas? Seem to know quite a bit anyway What i dont know is not worth knowing Rich. Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 23, 2009 Share Posted October 23, 2009 Something i've thought about doing, was replacing the seals as the rubber seems to have aged badly, especially along the bottom, anyone know where to get this for the 'M' or is it just generic stuff you cut to fit, like i've seen in halfords?Do you mean the seal the window runs in or the scrapper moulding that goes along the top of the door ,eather way its a scrappy or honda / rover part only. I need all 4 scapper moulds if someone know the price of them . Rich. Link to comment Share on other sites More sharing options...
ShortySco Posted October 23, 2009 Share Posted October 23, 2009 Yeah the scraper bit, same as yourself, all 4, it's all pitted and has furry stuff on it, new parts from honda i think it'll have to be, dread to imagine the prices though.... Link to comment Share on other sites More sharing options...
